大家好,
我想购买一台带有两个处理器的服务器,每个处理器至少支持16个核心,我还需要它们支持CMT,MBM,L3 CAT和L3 CDP,在理想的世界中它们也支持MBA。 我已经读过家庭E5xxxx v4支持CMT,MBM,L3 CAT和L3 CDP,但我不确定所有型号都支持这些功能。 有人可以向我确认一个支持4种功能的处理器,至少16个核心和多处理器。 我还没有找到具有这些功能的官方英特尔表。 提前致谢 以上来自于谷歌翻译 以下为原文 Hello every body, I want to buy a server with two processors that each supports at least 16 cores, also I need they support CMT, MBM, L3 CAT and L3 CDP, in a ideal world they also support MBA. I have read that the family E5xxxx v4 support CMT, MBM, L3 CAT and L3 CDP but I not sure that all models support these features. Could somebody confirm me a processor that supports the 4 features, at least 16 cores and multi processor. I have not found a official Intel table with these features. Thanks in advance |
5个回答
好吧,你显然没有访问或玩过ARK.INTEL.COM ......
如果你想坚持Xeon E5系列,那么NONE就有16个内核。 然而,有许多有16个超线程。 以下是所有具有至少16个超线程的Xeon E5系列处理器的比较(使用ARK.INTEL.COM网站的功能):英特尔®产品规格比较。 现在,如果你进入Xeon E7系列,你会发现许多处理器拥有16个或更多内核。 以下是这些处理器的比较:英特尔®产品规格比较。 我把它作为练习让你看看这些比较,并验证你所需的其他功能也得到支持...... 希望这可以帮助, 内容S 以上来自于谷歌翻译 以下为原文 Well, you obviously haven't visited or played with ARK.INTEL.COM... If you want to stick with the Xeon E5 family, there are NONE with 16 cores. There are many that have 16 hyperthreads, however. Here is a comparison (using the capabilities of the ARK.INTEL.COM site) of all of the Xeon E5 family processors that have at least 16 hyperthreads: Intel® Product Specification Comparison. Now, if you step up into the Xeon E7 family, you will find many processors that have 16 or more cores. Here is a comparison of those processors: Intel® Product Specification Comparison. I leave it as an exercise for you to look at these comparisons and verify that the other features that you desire are also supported... Hope this helps, ...S |
tianyou15 发表于 2018-11-6 10:14 感谢您的回复。 实际上我已经检查过ark.intel.com并且我使用了比较工具,但是CAT,CMT,MBM和CDP没有被列为功能,所以我不确定特定型号是否有它们。 另外,我检查了Xeon E5 v4超过16个核心,如E5-4660 v4,E5-4667 v4,E5-4669 v4,E5-2699x等,但我没有找到官方的英特尔文件,如果这些处理器有 我正在寻找或不寻找的功能。 最好的祝福 以上来自于谷歌翻译 以下为原文 Thanks for your reply. Actually I already check ark.intel.com and I have used the comparison tool, but CAT, CMT, MBM and CDP are not listed as features, so I not sure if a specific model have them or do not. Also I checked that there are Xeon E5 v4 with more than 16 cores like E5-4660 v4, E5-4667 v4, E5-4669 v4, E5-2699x among others, but I have not find an official Intel document if these processors have the features I am looking for or do not. Best Regards |
huwwwwf 发表于 2018-11-6 10:31 你是绝对正确的! 有多奇怪......我不确定为什么我做的第一个查询不包括所有的E5系列处理器; 我以为我做了同样的查询但是第二次在显示器中包含了*很多*更多的处理器...... 至于包含哪些功能,你也是对的(我没有看到)。 您需要做的是使用比较(此时更正:英特尔®产品规格比较)来确定所代表的处理器体系结构,然后您可以查找这些特定功能的存在。 对于E5和E7,我可以看到Haswell(V3)和Broadwell(V4)的例子。 您可以查看这两种体系结构的数据表,然后确定支持的功能。 当然,这说起来容易做起来难...... 内容S 以上来自于谷歌翻译 以下为原文 You are absolutely right! How odd... I am unsure why the first query that I did didn't include all of the E5 family processors; I thought I did the same query yet the second time a *lot* more processors were included in the display... As for what features are included, you are also right (I didn't look to see). What you will need to do is use the comparison (correct this time: Intel® Product Specification Comparison) to identify what processor architecture(s) are represented, you can then look for the presence of these particular features. For the E5 and E7, I can see Haswell (V3) and Broadwell (V4) examples. You can look at the datasheets for these two architectures to then determine of the features are supported. Of course, this is easier said than done... ...S |
huwwwwf 发表于 2018-11-6 10:31 Hirobalrr,如前所述,您可以使用数据表从Ark.intel.com获取该信息,您需要选择一个处理器,根据补充信息,您将看到数据表的链接,其中包含支持的说明, 很多这些处理器通常都包含在一个PDF中,因此找到一个尽可能多地调整到你想要的东西并不需要太多。让我知道你是否还需要其他东西.Eduardo_B 以上来自于谷歌翻译 以下为原文 Hi robalrr, As indicated before you will be able to get that information out Ark.intel.com with the Datasheets, you need to select one processor and under supplemental information you will see the link for the Datasheets that include the instructions that are supported, a lot of those processors are usually covered within a single PDF so it should not take much to find one that adjusts to as much as possible to what you are looking for. Let me know if you need anything else. Eduardo_B |
jerry1978 发表于 2018-11-6 10:58 Hirobalrr,如果您能够解决您的问题,或者您还有其他需要帮助的地方,请告诉我.Eduardo_B 以上来自于谷歌翻译 以下为原文 Hi robalrr, Please let me know if you were able to resolve your concern or if there is something else you may need assistance with. Eduardo_B |
GMT+8, 2025-7-19 06:44 , Processed in 0.591426 second(s), Total 72, Slave 66 queries .
