大家好,
在复位后第一次运行期间进行ADC1单次扫描转换(ADC0至ADC2通道)时,ADC2始终为0(ADC1和0均为正常)。接下来和接下来的几组读数都可以。它在STM8S Discovery(STM8S105C6)上进行测试。码: “” ADC_Config(); ADC1_StartConversion(); while(ADC1_GetFlagStatus(ADC1_FLAG_EOC)!= RESET) ; HS_buffer [0] = ADC1_GetBufferValue(2); SU_buffer [0] = ADC1_GetBufferValue(1); U_steu = ADC1_GetBufferValue(0); ADC1_DeInit(); “” 其中ADC_config(): “” ADC1_DeInit(); / * De-Init ADC外设* / / * Init ADC2外设* / ADC1_ScanModeCmd(ENABLE); ADC1_Init(ADC1_CONVERSIONMODE_SINGLE,ADC1_CHANNEL_2,ADC1_PRESSEL_FCPU_D2, ADC1_EXTTRIG_tiM,DISABLE,ADC1_ALIGN_RIGHT, ADC1_SCHMITTTRIG_CHANNEL0 | ADC1_SCHMITTTRIG_CHANNEL1 | ADC1_SCHMITTTRIG_CHANNEL2, DISABLE); “” 当我(在有问题的第一次运行期间)设置断点时 ''HS_buffer [0] = ADC1_GetBufferValue(2);''并执行步骤 - 结果正常。 我在重置后通过虚拟读取来解决它,但我想知道原因。 谢谢。 #stm8#adc1#single-scan 以上来自于谷歌翻译 以下为原文 Hello everybody, when doing ADC1 single scan conversion (ADC0 to ADC2 channels) during the first run after reset the ADC2 is always 0 (ADC1 and 0 are OK). The next and following sets of readings are then all OK. It is tested on STM8S Discovery (STM8S105C6). Code: '' ADC_Config(); ADC1_StartConversion(); while( ADC1_GetFlagStatus(ADC1_FLAG_EOC) != RESET) ; HS_buffer[0] = ADC1_GetBufferValue(2); SU_buffer[0] = ADC1_GetBufferValue(1); U_steu = ADC1_GetBufferValue(0); ADC1_DeInit(); '' where ADC_config(): '' ADC1_DeInit();/* De-Init ADC peripheral*/ /* Init ADC2 peripheral */ ADC1_ScanModeCmd(ENABLE); ADC1_Init(ADC1_CONVERSIONMODE_SINGLE, ADC1_CHANNEL_2, ADC1_PRESSEL_FCPU_D2, ADC1_EXTTRIG_TIM, DISABLE, ADC1_ALIGN_RIGHT, ADC1_SCHMITTTRIG_CHANNEL0 | ADC1_SCHMITTTRIG_CHANNEL1 | ADC1_SCHMITTTRIG_CHANNEL2, DISABLE); '' When I (during the problematic first run) set breakpoint on the ''HS_buffer[0] = ADC1_GetBufferValue(2);'' and do step- the result is OK. I solve it by dummy reading after reset, but I would like to know the reason. Thank You. #stm8 #adc1 #single-scan |
3个回答
当然,
应该有''== RESET''。现在它工作正常。有谁知道,如何删除线程?我认为这不是真的有用:-)。 以上来自于谷歌翻译 以下为原文 Of course, there should be '' == RESET''. Now it works fine. Does anybody know, how to delete the thread? I think it is not really helpful :-). |
这是一个3岁的帖子,论坛可能不会提醒,因为它在一年前被转移到了另一个平台。
以上来自于谷歌翻译 以下为原文 This is a 3-year old thread, forum may not alert since it was moved to a different platform a year ago. |
stm32mp157的异核通信的rpmsg_sdb的m4固件和a7驱动该如何编写?
921 浏览 0 评论
stm32f103用freertos对一个采样率为1kHz的传感器,进行采样,数据出差
978 浏览 0 评论
3135 浏览 1 评论
3408 浏览 1 评论
1998 浏览 1 评论
STM32H7打开DCache后,出现了串口接收信息为空的现象,是哪里出了问题?
153浏览 5评论
用NANO STM32F103RBT6的开发板烧录不了是哪里出了问题?
175浏览 5评论
195浏览 5评论
外部中断触发类型为双边沿触发,进入中断回调后有什么办法判断该边沿是上升沿还是下降沿?
234浏览 5评论
STM32L071CBT6低温环境下无法正常工作是什么原因引起的?
180浏览 5评论
GMT+8, 2025-7-8 09:21 , Processed in 0.500470 second(s), Total 46, Slave 41 queries .
