你好,
我们的客户已经下载了FX3 SDK V1.3.3,他们要求合法使用它。 EZ-USB FX3软件开发包 (1)他们能编辑和编译SDK安装文件夹中提供的源代码,将编译的固件写入FX3ROM并作为其产品销售吗? (2)他们可以复制驱动程序的目标代码(不需要修改和编辑),并通过CD分发以安装在终端用户的PC上吗? 请告诉我们是否有任何法律问题。 最好的问候, 以上来自于百度翻译 以下为原文 Hello, Our customer has downloaded FX3 SDK v1.3.3 and they are asking for legal usage of it. EZ-USB FX3 Software Development Kit | Cypress Semiconductor (1) Can they editing & compile the source code provided in SDK installed folder, write the compiled firmware to FX3 ROM and sell it as their product? (2) Can they duplicate the object code of the driver (without modification and editing) and distribute it by CD for installation on the end user's PC? Please tell us if there are any legal issue on this. Best Regards, |
嗨,Tran san,
是的,他们能。这两种行为都没有法律问题。 请注意,有2件事需要牢记。 1)他们必须只使用CyPress硅驱动器(他们不应该使用驱动器与其他芯片) 2)CyPress声称没有责任,如果源代码不工作后,他们自己编辑。 谢谢, 纳达 以上来自于百度翻译 以下为原文 Hi Tran-san, Yes, they can. There is no legal issue for both actions. Please kindly note that there are 2 things to keep in mind. 1) They must use the driver only with Cypress Silicon (They should not use the driver with some other chip) 2) Cypress claims no responsibility if the source code does not work after they edit themselves. Thanks, Nada |
767个成员聚集在这个小组
加入小组cyUSB3014一直显示2.1,不能到3.0情况,谁遇到过
690 浏览 0 评论
2220 浏览 1 评论
1972 浏览 1 评论
3792 浏览 1 评论
1875 浏览 6 评论
1817浏览 2评论
709浏览 2评论
532浏览 2评论
512浏览 2评论
1612浏览 2评论
GMT+8, 2025-5-10 17:53 , Processed in 0.726713 second(s), Total 42, Slave 37 queries .
