在使用数字I/O之后,PIN是否已经不再使用PIN?我有PSoC开发工具包和无意中分配一个数字I/O函数P0.5然后纠正分配回CapSense功能…,港口不再功能…CapSense功能我可以重新分配给另一个引脚和功能的作品…如果我分配回P0.5 W我不行…我指定数字的功能和它的作品好P0.5数字I / O。任何建议/解决方法吗?
以上来自于百度翻译 以下为原文 Are there any known issues with pins no longer working for capsense after being used for digital I/O? I have the PSoC Development kit and accidently assigned a digital I/O function to P0.5 and then corrected the assignment back to capsense function...the capsense function for that port no longer functions...I can reassign it to another pin and the functionality works...if I assign back to P0.5 it will not work...I assigned P0.5 for digital functions and it works fine for digital I/O...Any suggestions/workarounds? |
Smuraski,他们有没有机会把P0(5)连接到开发工具箱的电路板上?您不应该分配具有不同功能的CAPSENSE PIN,然后再将其重新设置。问候,Bobby
以上来自于百度翻译 以下为原文 Smuraski, Is their any chance that you have P0[5] wired to something on the development kit's breadboard? You should have no issues assigning a CapSense pin with a different functionality, and then later setting it back. Regards, Bobby |
你好,
您可以这样尝试:首先将Pin属性作为Pin属性窗口中的默认值。然后把PIN重新分配到CopSoad向导中,然后我认为它应该工作。 当做, 谢希尔 以上来自于百度翻译 以下为原文 Hi, You can try like this: First make the pin properties as default in pin properties window. and then reassign the pin to capsense into the capsense wizard. then I Think it should work. regards, Sheshmal |
767个成员聚集在这个小组
加入小组cyUSB3014一直显示2.1,不能到3.0情况,谁遇到过
761 浏览 0 评论
2222 浏览 1 评论
1973 浏览 1 评论
3793 浏览 1 评论
1876 浏览 6 评论
1861浏览 2评论
710浏览 2评论
533浏览 2评论
515浏览 2评论
1687浏览 2评论
GMT+8, 2025-5-12 08:49 , Processed in 0.760724 second(s), Total 46, Slave 41 queries .
