我下载了两种不同格式的ISE 14.7安装文件 - 拆分安装程序(4个文件)和完整安装程序。
我尝试在Windows 7,64位机器上安装。 我发现不可能从这两个中安装。 在安装过程中,我收到安装过程无法写入文件夹(PlanAhead或ISE / ISE_DS)的错误。 我检查文件夹的属性,发现它已变为只读。 然后我修改文件夹(和子文件夹)的属性,然后继续安装(重试)。 它向前移动1%,然后再次报告相同的错误。 权限再次恢复为只读! 对于PlanAhead,它在最终安装之前会持续2-3次。 但对于ISE,子文件夹中的文件数超过100,000。 这需要花费大量时间来更改权限。 然后它再慢慢完成1%,再次报告同样的恼人错误。 我尝试了3次(使用拆分安装程序两次,使用完整安装程序一次)。 我甚至禁用了我的防病毒软件。 我发现安装不能超过71%(卡在ISE_DS)。 ISE 14.6没有遇到任何这些问题(即使启用了防病毒)。 我想知道Xilinx人员是否在上传到他们的网站之前检查了ISE 14.7是否可以安装。 问候, 拉杰什 以上来自于谷歌翻译 以下为原文 I downloaded two different formats of ISE 14.7 install files - the split installer (4 files) and the full installer. I tried installing on Windows 7, 64-bit machine. I am finding it impossible to install from either of these. During installation, I get the error that the installation process is not able to write to the folder (PlanAhead or ISE/ISE_DS). I check up the properties of the folder, and I find that it has become read-only. I then modify the property of the folder (and subfolders), and then proceed with the installation (retry). It moves ahead 1%, and then again reports the same error. Again the permissions have reverted to read-only! For PlanAhead this goes on 2-3 times, before it finally installs. But for ISE, the number of files within the subfolders exceeds 100,000. This takes lot of time changing the permissions. Then it slowly completes 1% more, before again reporting the same irritating error. I tried this 3 times (twice with the split installer, and once with full installer). I even disabled my anti-virus. I am finding that the installation can't proceed beyond 71% (stuck at ISE_DS). ISE 14.6 went through without any of these issues (even with anti-virus enabled). I want to know whether Xilinx personnel had checked up whether ISE 14.7 is installable before uploading on their website. regards, rajesh |
嗨Rajesh,请尝试从这个链接下载,看看是否有帮助.http://www.xilinx.com/support/answers/57840.html
谢谢,维杰----------------------------------------------- ---------------------------------------------请将帖子标记为 一个答案“接受为解决方案”,以防它有助于解决您的查询。如果一个帖子引导到解决方案,请给予赞誉。 以上来自于谷歌翻译 以下为原文 Hi Rajesh, Please try downloading from this link and see if that helps. http://www.xilinx.com/support/answers/57840.htmlThanks,Vijay -------------------------------------------------------------------------------------------- Please mark the post as an answer "Accept as solution" in case it helped resolve your query. Give kudos in case a post in case it guided to the solution. |
另请参阅http://www.xilinx.com/support/documentation/sw_manuals/xilinx14_7/irn.pdf
_______________________________________________如果有助于解决您的查询,请将此帖子标记为“接受为解决方案”。 因此,它将有助于其他论坛用户直接参考答案。如果您认为该信息有用且面向答复,请给予此帖子称赞。 以上来自于谷歌翻译 以下为原文 Also refer http://www.xilinx.com/support/documentation/sw_manuals/xilinx14_7/irn.pdf ________________________________________________ Please mark this post as an "Accept as solution" in case if it helped to resolve your query. So that it will help to other forum users to directly refer to the answer. Give kudos to this post in case if you think the information is useful and reply oriented. |
2694 浏览 7 评论
3012 浏览 4 评论
2433 浏览 9 评论
3539 浏览 0 评论
2636 浏览 15 评论
3420浏览 1评论
835浏览 1评论
696浏览 1评论
GMT+8, 2025-7-5 12:09 , Processed in 1.451805 second(s), Total 76, Slave 60 queries .
