您好,我正在尝试制作一个简单的工具,使用Agilent命令Expert从E4404B频谱分析仪手动检索数据。
我想手动配置我的测量,然后运行脚本将显示器上的数据传输到Excel,而不是设置程序来控制分析器。 我有一些功能,但我需要检索当前显示在设备上的频率开始和停止频率。 我不希望在检索数据之前强迫用户在计算机上输入频率限制。 我能够检索幅度数据和数据点的数量,但是如何检索当前显示在仪表上的迹线的频率信息? 我正在使用IVI-com驱动程序,但使用GPIB命令完成此操作的建议也会有所帮助。 谢谢,克里斯 以上来自于谷歌翻译 以下为原文 Hello, I am attempting to make a simple tool to manually retrieve data from the E4404B Spectrum Analyzer using Agilent command Expert. Instead of setting up a program to control the analyzer, I want to manually configure my measurement and then run a script to transfer the data on the display to Excel. I have some functionality, but I need to retrieve the frequency start and stop frequencies currently displayed on the unit. I don't want the user to be forced to enter the frequency limits on the computer before retrieving data. I am able to retrieve the amplitude data and the number of data points, but how can I retrieve the frequency information for the trace currently displayed on the meter? I am working with the IVI-com drivers, but suggestions for accomplishing this using GPIB commands would help as well. Thanks, Chris |
嗨克里斯 - 如果你需要SCPI从分析仪中检索开始和停止频率,命令是:FREQ:STAR?
(开始频率查询):FREQ:STOP? (停止频率查询)我希望这有帮助 - 以上来自于谷歌翻译 以下为原文 Hi Chris - If you need the SCPI to retrieve start and stop frequency from the analyzer, the commands are: :FREQ:STAR? (start frequency query) :FREQ:STOP? (stop frequency query) I hope this helps - |
1599 浏览 0 评论
2556 浏览 1 评论
2426 浏览 1 评论
2261 浏览 5 评论
3197 浏览 3 评论
1010浏览 0评论
1600浏览 0评论
GMT+8, 2025-7-8 13:56 , Processed in 1.135418 second(s), Total 44, Slave 39 queries .
