HI ALL,我使用:MPLABX V3Y51和I安装了新版本的HARMony Ccnfigurator(V2Y02YY0B),但是当我尝试从应用程序实例文件夹打开一个现有的项目时(即:C:Microchip HyralV2Y02YO0B\AppGFX ARIAY-WeethyRead),在和声配置上比较错误预设。NT在附件中写道:“MPLAB HAMRONI配置器初始化失败”,我如何解决这个问题?谢谢。
以上来自于百度翻译 以下为原文 Hi all, I use : MPLABX v3_51 and I installed the new version of Harmony Ccnfigurator (v2_02_00b) but when I try to open an existing project from the applications examples folder (i.e. : "C:microchipharmonyv2_02_00bappsgfxaria_weather_forecast"), on Harmony Configuration compare the error present in attachment (it writes: "MPLAB Hamrony Configurator failed to initialize"). How can i Solve this problem? Thank's in advance Marco P. Attached Image(s) |
3个回答
迄今为止,MHC是一个相对的术语。和谐和MHC的版本必须匹配。(版本号不总是正确的)自动下载是V1.10。MHC既不向前也不向后兼容。
以上来自于百度翻译 以下为原文 Upto date is a relative term with MHC. The version of harmony and MHC must match. (The version number is not always correct) the auto download is v1.10. MHC is neither forward nor backwards compatible. |
大家好,谢谢你的建议。我用MHC和谐配置器解决了我的问题,位于“和谐 XXXXX 公用事业 MHC”中:将来我会一直使用它,而不是出现在Microchip的和谐工具下载网站上。!!!非常感谢AlMARCO P.
以上来自于百度翻译 以下为原文 Hi all, thanks for your suggestions. I solved my problems using the Mhc Harmony Configurator located inside "harmonyxxxxxutilitiesmhc" : in the future I will use it always instead that is present on Microchip's Harmony tools download site!!! Thanks very much at all Marco P. |
有多种版本的和声并不是混淆它的原因。MPLABX从服务器中提取版本。做一个和谐安装不更新MHC在MPLabX。如果服务器版本不是您正在使用的版本,则必须进行手动安装。
以上来自于百度翻译 以下为原文 Having multiple versions of harmony is not what confuses it. MPLabX pulls the version from the server. Doing a harmony install does not update the MHC in MPLabX. You must do a manual install if the server version is not the one you are using. |
5486 浏览 9 评论
2171 浏览 8 评论
2071 浏览 10 评论
3336 浏览 3 评论
2374 浏览 5 评论
981浏览 1评论
835浏览 1评论
838浏览 1评论
869浏览 0评论
我是Microchip 的代理商,有PIC16F1829T-I/SS 威廉希尔官方网站 问题可以咨询我,微信:A-chip-Ti
569浏览 0评论
GMT+8, 2025-5-13 02:53 , Processed in 0.969858 second(s), Total 46, Slave 41 queries .
