如果您正在使用微型光纤处理器并编译软件代码并且整个图像适合FPGA RAM ...则成为ROM。
这是否意味着您每次要进行软件更改时都必须重新编译FPGA并获取新的.bit文件? 有更简单的方法吗? 此外,如果软件映像无法放入FPGA内部,可以将其放置在BPI闪存(配置闪存)等位置,然后通过存储在FPGA RAM中的引导加载程序加载到外部RAM中吗? 如果可以,那么需要哪些元件/电路走线才能实现这一目标? 以上来自于谷歌翻译 以下为原文 If you're using a microblaze processor and compile the software code and the entire image fits inside FPGA RAM...becomes a ROM. Does this mean you have to recompile the FPGA and get a new .bit file everytime you want to make a software change? Is there an easier method? Also, If the software image cannot fit inside FPGA RAM, can it be placed in a place such as BPI flash (configuration flash) and then be loaded into external RAM with a bootloader stored in FPGA RAM? If this is possible, what components/circuit traces are needed to make this realizable? |
eilert,比如我在启动时将引导加载程序存储在RAM中,并将整个软件映像存储在闪存中。
如果没有足够的内部微型RAM,那么我是否需要在系统中安装RAM芯片 RAM的大小> =软件映像的大小? 此外,软件映像是否可以存储在与BPI类型配置的配置闪存相同的闪存中? 以上来自于谷歌翻译 以下为原文 eilert, say I have the bootloader stored in RAM on powerup and I have the entire software image stored in flash. If there is not enough internal microblaze RAM, then would I need to install a RAM chip in the system where size of RAM >= size of software image? Also, can the software image be stored in the same flash as the configuration flash for BPI type configurations? |
2622 浏览 7 评论
2951 浏览 4 评论
2389 浏览 9 评论
3493 浏览 0 评论
2570 浏览 15 评论
3197浏览 1评论
743浏览 1评论
629浏览 1评论
GMT+8, 2025-5-12 02:37 , Processed in 1.247990 second(s), Total 77, Slave 61 queries .
