你好,
我试图在Windows 7, 64位OS上安装FX3.0的驱动程序,但我失败了。基于CysB.PDF,我必须使用“X64”文件夹,但是,在Wi7(X86)下没有这样的文件夹。有没有Wi7 x64的驱动程序? 谢谢, 纳西拉 以上来自于百度翻译 以下为原文 Hi, I am trying to install the driver for the FX3.0 on windows 7, 64-bit os, but I am unsuccessful. Based on the CyUSB.pdf, I have to use the "x64" folder, however, there is no such a folder under win7 (only x86). Is there any driver for win7 x64? Thanks, Nazila |
25个回答
这很清楚,但是司机现在还没有签字。所以每次启动时你都必须使用F8破解。
以上来自于百度翻译 以下为原文 This is clear, but nevertheless the driver isn´t signed at the moment. So you always have to use the F8 hack at every boot up. |
为了避免恼人的F8启动,请用测试证书给驱动程序签名。你可以在这里找到血淋淋的细节:
HTTP://www. mias./com /NexS0903.HTM/NWS0903.HTM 阿德里安 以上来自于百度翻译 以下为原文 To avoid the annoying F8 boot, sign the driver with a test certificate. You can find the gory details here: http://www.minasi.com/newsletters/nws0903.htm Adrian |
X64驱动器在“程序文件”下,如果软件是32位,则x86使用“x86”文件夹。
以上来自于百度翻译 以下为原文 X64 drive is under the ”programfiles“,if the software is 32bit, there X86 is use the "x86" folder |
你好,
我们在W7上安装FX3 X64 DRIVER有困难。 我们使用CySutheUsB3xx64×B562.MSI来安装引导加载程序,并在启动时禁用信号验证,但仍然可以安装驱动程序。代码(10)是错误。 更新管理器显示EZ-USB FX3SDK1.2.1。 CysB3.IF: Deice DISC%%CYSUB3,USB VIDY04B4&PIDY0.00 F0%VIDU04B4&PIDY00 F1.DEVICESDESC% = CYSB3,USB VIDY04B4&PIDY00 F1%VIDY04B4&PIDY00 F3 . DeVice DISC%= CYSB3,USB VIDY04B4和PIDY00 F3%VIDY04B4和PIDY47 %VIDYXXXX和PIDYXXX.DEVICESDESCC%= CYUB3,USB VIDYXXXX和PIDYXXXX %VIDY04B.Deice DeCs%=CysB3,USB VIDY04B4和PIDY47 设备管理器: CyPress USB Bootloader带有黄色三角形感叹号。 赞赏。 以上来自于百度翻译 以下为原文 Hi, We're having trouble to install the Fx3 x64 dirver on win7. we used CySuiteUSB3_x64_B562.msi to install the Bootloader and disable the Signal verification when bootup, but still can have the driver installed. Code(10) was the error. The Update Manager shows EZ-USB FX3 SDK 1.2.1. cyu***3.inf: ;%VID_XXXX&PID_XXXX.DeviceDesc%=CyU***3, USBVID_XXXX&PID_XXXX %VID_04B4&PID_00F0.DeviceDesc%=CyU***3, USBVID_04B4&PID_00F0 %VID_04B4&PID_00F1.DeviceDesc%=CyU***3, USBVID_04B4&PID_00F1 %VID_04B4&PID_00F3.DeviceDesc%=CyU***3, USBVID_04B4&PID_00F3 %VID_04B4&PID_4720.DeviceDesc%=CyU***3, USBVID_04B4&PID_4720 Device Manager: Cypress USB BootLoader with Yellow triangle Exclamation. Appriciated. |
你好,
请您附上显示设备管理器错误的屏幕截图(右键单击带有惊叹号的设备,选择“属性”并选择“常规选项卡”)。还检查并让我们知道VID/PID在设备管理器中显示的内容(右键单击带有惊叹号的设备,选择“属性”并选择“详细信息”选项卡;从LSET框中选择“硬件ID”。 当做, 加亚特里 以上来自于百度翻译 以下为原文 Hi, Can you please attach screenshot showing the error in device manager (right click on the device with exclamation, select 'Properties' and select General tab). Also check and let us know what is the VID/PID being shown in the device manager (right click on the device with exclamation, select 'Properties' and select 'Details' tab; select 'Hardware IDs' from lsit box). Regards, Gayathri |
对不起打扰你了。我想我也有同样的错误。
详细说明: 21.3 K 以上来自于百度翻译 以下为原文 Sorry to trouble you. I guess I have the same error.
你好,
这是因为没有签名的INF文件。为了克服这个问题,在系统启动时,按下F8并选择“可驱动的驱动器签名执行”选项。 不过,我想检查一件事。FX3SDK通常带有签名的INF文件,签名如下CyPress VID/PID对: 1。0x04B4/0x00 F0 2。0x04B4/0x00 F1 三。0x04B4/0x00 F3 4。0x04B4/0x47 20 是否修改了用于绑定驱动程序的INF文件?如果是这样,它将成为未签名的,那么这个错误/警告是预期的。 当做, 加亚特里 以上来自于百度翻译 以下为原文 Hi, It is just because of unsigned inf file. In order to overcome this, while system bootup, press F8 and select "Diable driver signature enforcement" option. However, I would like to check one thing. FX3 SDK usually comes with signed inf file, signed for the following Cypress VID/PID pairs: 1. 0x04B4/ 0x00F0 2. 0x04B4/ 0x00F1 3. 0x04B4/ 0x00F3 4. 0x04B4/ 0x4720 Did you modify the inf file being used to bind the driver? If so, it will become unsigned, then this error/ warning is expected. Regards, Gayathri |
谢谢一百万。我使用了原始的INF文件。我会努力追随你的。
以上来自于百度翻译 以下为原文 Thanks a million. I used original inf file. I will try to follow your recomendation. |
好,
我终于明白了。旧的驱动程序版本在驱动程序商店中运行,损坏了游戏。现在一切正常。 再次感谢您的帮助。-) 以上来自于百度翻译 以下为原文 Well, I finally understood. The old driver version is strored in Driver Store and spoiled the game. Now all work normally. Thank you again for help. :-) |
你得到的错误信息是什么?
启动时禁用驾驶员签名执行吗? 当做, 阿南德 以上来自于百度翻译 以下为原文 What is the error message you're getting? Have you disabled driver signature enforcement while booting up? Regards, Anand |
你好,
如何获得Windows 7 X64 OS数字签名的CyPress X64驱动程序? 谢谢, D.Y.NA 以上来自于百度翻译 以下为原文 Hi, How do i get the cypress x64 driver with digital signature for windows 7 x64 OS? thanks, D.Y. Na |
我也有同样的问题。我今天收到了FX3 DeV板,似乎DeV套件不包括X64设备驱动程序。我在哪里得到X64驱动程序?
另外,我注意到x86驱动程序没有签名。我假设目的是让最终用户签署驱动程序,并将这些产品交付给终端产品。什么是计划,为什么他们不只是包含在Windows更新? 谢谢。 以上来自于百度翻译 以下为原文 I have the same problem. I received the FX3 dev. board today and it seems the dev kit does not include x64 devices drivers. Where do I get the x64 drivers? Also, I note the x86 drivers are not signed. I assume the intention is for the end user to sign the drivers and deliver these with the end product. What is the plan and why are they not just included in the Windows update? Thanks. |
断然的。因此,我注意到DVD与DeV板X86默认地安装驱动程序,例如:
C:程序文件(x86) CyPress EZ-USB FX3 SDK 1驱动器bin \Wi7\ 如果我安装,& DVD;Gt::EZ-USB FX3SDK 7 CySutheUsB3xx64·B29 9MSI,那么X64驱动器在这里,例如 C:CyPress CyPress超高速UBSub 驱动程序bin Win 7. 以上来自于百度翻译 以下为原文 Resolved. So I note the DVD with the dev board x86 installs drivers here by default, e.g.: C:Program Files (x86)CypressEZ-USB FX3 SDK1.0driverbinwin7 if I install, C:CypressCypress SuperSpeed USBSuitedriverbinwin7 |
我们正在为我们的DVK认证司机。我们将很快进行修改,只添加签名的驱动程序。
将在这里进行一次更新。 当做, 阿南德 以上来自于百度翻译 以下为原文 We're working on certifying the driver for our DVK. We'll soon be doing a revision to add just the signed drivers. Will update here once that is done. Regards, Anand |
我的FAE告诉我四月的驾驶执照。
以上来自于百度翻译 以下为原文 My FAE told me the driver certification is expected in April. |
我认为CyPress应该让未经验证的X64签名的驱动程序可供开发人员使用。不管怎样,为了我的使用,我已经签了名。
当连接到USB 2端口时,驱动程序有时会加载OK,有时我会得到“Windows已经停止了这个设备,因为它报告了问题。(代码43)这是一个已知的问题吗? CyPress驱动程序无法加载“此设备无法启动”。(代码10)“当连接到USB 3端口时”。 我使用的X64 Wi7最终SP1与AsMuleXHCI控制器的USB 3(华硕P8Z68VPRO主板)和FX3 DVK RVIII。我在某个地方读到DeV板只测试了NEC USB 3主机控制器——这是正确的吗?如果是的话,预计什么时候在ASMITER XHCI主机控制器和英特尔IVY桥芯片组USB 3主机控制器上进行测试? 如果你想给我一个X64检查的驱动程序的构建,我可以发送调试日志,如果有帮助的话。 FY,32位驱动程序似乎使用英特尔USB 2主机控制器在32位XP上工作。 以上来自于百度翻译 以下为原文 I think Cypress should just make the uncertified x64 signed drivers available to developers. Anyway, for my use I have signed the driver. The driver loads OK sometimes when connected to a USB 2.0 port, and sometimes I get “Windows has stopped this device because it has reported problems. (Code 43)”. Is this a known problem? The Cypress driver fails to load with “This device cannot start. (Code 10)” when connected to a USB 3.0 port. I am using x64 Win7 Ultimate SP1 with a ASMedia XHCI Controller for USB 3.0 (ASUS P8Z68-VPRO motherboard) and the FX3 DVK rev3. I read somewhere that the Dev board has only been only tested with the NEC USB 3.0 Host controller – is this correct? If so, when is it expected to be tested on the ASMedia XHCI Host controller and on the Intel Ivy Bridge chipset USB 3.0 Host Controller? If you want to send me an x64 Checked build of the driver, I can send you the debug log if that helps. FYI, the 32-bit driver seems to work on 32-bit XP with an Intel USB 2.0 Host Controller. |
万一其他人在ASMIUS USB 3主机控制器端口上有一个DVK问题,CyPress威廉希尔官方网站
支持告诉我这是AsMeST主机控制器的一个已知问题,并且下载最新的XHCI驱动程序栈版本1.1.1.0来解决这个问题。
我从主板制造商网站测试了1.100.0,问题得到了解决。 以上来自于百度翻译 以下为原文 Just in case anyone else has a problem with the DVK on an Asmedia USB 3.0 host controller port, Cypress technical support adviced me that this is a known issue with the ASMedia host controller and to download the latest xHCI driver stack version 1.10.1.0 to resolve this issue. I tested with 1.10.0.0 from the motherboard manufactuers website and the problem is resolved. |
775个成员聚集在这个小组
加入小组cyUSB3014一直显示2.1,不能到3.0情况,谁遇到过
3769 浏览 0 评论
2311 浏览 1 评论
2029 浏览 1 评论
3874 浏览 1 评论
1930 浏览 6 评论
4401浏览 2评论
2926浏览 2评论
590浏览 2评论
569浏览 2评论
4676浏览 2评论
GMT+8, 2025-7-20 09:44 , Processed in 1.301320 second(s), Total 78, Slave 73 queries .
