Error: Integer value 30709 can not be written in columns 59-62 on line 75.
Error: Integer value 30709 can not be written in columns 59-62 on line 82. ------------------------------------------ SUMMARY: Errors: 2 Warnings: 0 Info: Most likely cause of "Integer value" errors are: - (Most likely) Coordinates in the database exceed IPC's coordinate system. Try setting the database origin to center the design to reduce the large coordinate values. - Large pad sizes. Reduce any large pad sizes. |
4263 浏览 2 评论
8302 浏览 2 评论
13892 浏览 1 评论
如何设置才能使AD中的设置允许同一根线上摆放不同的Net Label网络?
8383 浏览 3 评论
18288 浏览 1 评论
GMT+8, 2025-7-17 23:40 , Processed in 0.455768 second(s), Total 43, Slave 37 queries .
