扫一扫,分享给好友
嗨,
我买了''steval-mki126v1''和''steval-mki138v1''评估板(以及''Microphone Coupon Board steval-mki129v1'')。 我的目标只是记录来自每个麦克风/通道的信号(产生WAV文件)。 1)当我在''steval-mki138v1'上使用APWorkbench时,尝试记录(按下''start''),下一个弹出消息显示:mmioOpen: - 2147467259,阻止我生成WAV文件。 2)在''steval-mki129v1'上使用APWorkbench(通过steval-mki138v1和USB连接器),不要选择将任何通道捕获/记录到音频文件,我该如何获取这些数据? 非常感谢 大卫 以上来自于谷歌翻译 以下为原文 Hi, I've bought ''steval-mki126v1'' and ''steval-mki138v1'' evaluation boards (and ''Microphone Coupon Board steval-mki129v1'') . My goal is only to RECORD the signals coming to each microphone/channel (produce a WAV files). 1) When I use APWorkbench on ''steval-mki138v1'', try to record (pressing on ''start''), the next pop-up message shows: mmioOpen:- 2147467259, prevent me to produce the WAV files. 2) Using APWorkbench on ''steval-mki129v1'' (via steval-mki138v1 and USB connector), don't give option to capture/record any channel to audio file, how can I get those data? Thanks a lot David |
4个回答
嗨大卫,
APWorkbench允许通过“USB数字录音机”面板记录安装在STAudioHub接口上的MEMS麦克风的实时流。这是你在下面的case-1中选择并产生mmioOpen错误的那个吗? 马尔科 以上来自于谷歌翻译 以下为原文 Hi David, The APWorkbench allows to record live streams from the MEMS microphones mounted on the STAudioHub interface - through the ''USB Digital Voice Recorder'' panel. Is it this one that you're selecting in your below case-1 and producing the mmioOpen error? Marco |
亲爱的马可,
我试图清楚地解释我们的团队问题, 请参阅附件, 谢谢! 大卫 以上来自于谷歌翻译 以下为原文 Dear Marco, I've tried to explain clearly our team problems, Please see the attached file, Thanks! David |
嗨,
我也有和大卫一样的问题。此外,当我尝试播放录制的声音时,虽然它在视觉上在屏幕上播放,但它不会提供任何声音输出。有针对这个的解决方法吗? 亲切的问候, 法提赫 以上来自于谷歌翻译 以下为原文 Hi, I also have the same issue as David. In addition, when i try to play the sound that is recorded, although it plays it on screen visually, it does not give any sound output. Is there a solution to this? Kind regards, Fatih |
stm32mp157的异核通信的rpmsg_sdb的m4固件和a7驱动该如何编写?
932 浏览 0 评论
stm32f103用freertos对一个采样率为1kHz的传感器,进行采样,数据出差
983 浏览 0 评论
3150 浏览 1 评论
3413 浏览 1 评论
2006 浏览 1 评论
STM32H7打开DCache后,出现了串口接收信息为空的现象,是哪里出了问题?
164浏览 5评论
用NANO STM32F103RBT6的开发板烧录不了是哪里出了问题?
180浏览 5评论
202浏览 5评论
外部中断触发类型为双边沿触发,进入中断回调后有什么办法判断该边沿是上升沿还是下降沿?
248浏览 5评论
STM32L071CBT6低温环境下无法正常工作是什么原因引起的?
188浏览 5评论
GMT+8, 2025-7-16 08:56 , Processed in 0.553658 second(s), Total 50, Slave 45 queries .
