扫一扫,分享给好友
W25Q64
SPI配置步骤 1.使能SPI时钟 2.使能GPIO端口时钟 3.初始化GPIO,配置引脚模式 4.初始化SPI 5.使能SPI 6.SPI读写数据 7.查看SPI传输状态 举例 typedef struct { uint16_t SPI_Direction; uint16_t SPI_Mode; uint16_t SPI_DataSize; //数据帧格式 uint16_t SPI_CPOL; //时钟极性 uint16_t SPI_CPHA; //时钟相位 uint16_t SPI_NSS; //软件从设备管理 uint16_t SPI_BaudRatePrescaler; //波特率控制 uint16_t SPI_FirstBit; //帧格式 uint16_t SPI_CRCPolynomial; //CRC多项式寄存器 }SPI_InitTypeDef; #define EN25X_WriteEnable 0x06 #define EN25X_WriteDisable 0x04 #define EN25X_ReadStatusReg 0x05 #define EN25X_WriteStatusReg 0x01 #define EN25X_ReadData 0x03 #define EN25X_FastReadData 0x0B #define EN25X_FastReadDual 0x3B #define EN25X_PageProgram 0x02 #define EN25X_BlockErase 0xD8 #define EN25X_SectorErase 0x20 #define EN25X_ChipErase 0xC7 #define EN25X_PowerDown 0xB9 #define EN25X_Continue_Read 0xFF #define EN25X_ReleasePowerDown 0xAB #define EN25X_DeviceID 0xAB #define EN25X_ManufactDeviceID 0x90 #define EN25X_JedecDeviceID 0x9F void SPI_init() { GPIO_InitTypeDef gpio = { GPIO_Pin_13 | GPIO_Pin_14 | GPIO_Pin_15, GPIO_Speed_50MHz, GPIO_Mode_AF_PP }; SPI_InitTypeDef spi = { SPI_Direction_2Lines_FullDuplex, SPI_Mode_Master, //0x0104 SPI_DataSize_8b, SPI_CPOL_High, SPI_CPHA_2Edge, SPI_NSS_Soft, SPI_BaudRatePrescaler_256, SPI_FirstBit_MSB, 7 }; RCC_APB1PeriphClockCmd(RCC_APB1Periph_SPI2, ENABLE); //使能SPI时钟 RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB, ENABLE); //使能GPIO端口时钟 GPIO_Init(GPIOB, &gpio); //初始化GPIO,配置引脚模式 SPI_Init(SPI2, &spi); //初始化SPI SPI_Cmd(SPI2, ENABLE); //使能SPI } void SPI2_SetSpeed(u8 rate) { SPI2-》CR1 &= 0xFFC7; SPI2-》CR1 |= rate; SPI_Cmd(SPI2, ENABLE); } void EN25Q64_init() { GPIO_InitTypeDef gpiob = { GPIO_Pin_12, GPIO_Speed_50MHz, GPIO_Mode_Out_PP }; GPIO_InitTypeDef gpiog13 = { GPIO_Pin_13, GPIO_Speed_50MHz, GPIO_Mode_Out_PP }; GPIO_InitTypeDef gpiog14 = { GPIO_Pin_13, GPIO_Speed_50MHz, GPIO_Mode_Out_PP }; GPIO_InitTypeDef gpiof = { GPIO_Pin_9, GPIO_Speed_50MHz, GPIO_Mode_Out_PP }; RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB | RCC_APB2Periph_GPIOG | RCC_APB2Periph_GPIOF, ENABLE); GPIO_Init(GPIOB, &gpiob); SPI2_NSS = 1; //以太网模块片选(拉高,防止干扰) GPIO_Init(GPIOG, &gpiog13); FLASH_CS = 1; //FLASH片选 GPIO_Init(GPIOG, &gpiog14); SD_CS = 1; //SD卡模块片选 GPIO_Init(GPIOF, &gpiof); TUB_4 = 1; //NRF24L01模块片选 SPI_init(); } u8 SPI_read_write(u16 d) //SPI读写数据 { while(SPI_I2S_GetFlagStatus(SPI2, SPI_I2S_FLAG_TXE) != SET); SPI_I2S_SendData(SPI2, d); while(SPI_I2S_GetFlagStatus(SPI2, SPI_I2S_FLAG_RXNE) != SET); return SPI_I2S_ReceiveData(SPI2); } u16 EN25Q64_read_id() { u16 r; FLASH_CS = 0; SPI_read_write(EN25X_ManufactDeviceID); SPI_read_write(0); //dummy SPI_read_write(0); SPI_read_write(0); r = SPI_read_write(EN25X_Continue_Read) 《《 8; r = SPI_read_write(EN25X_Continue_Read); FLASH_CS = 1; return r; } void EN25Q64_read_unique_id(u8 *id) { int i = 0; FLASH_CS = 0; SPI_read_write(0x4B); SPI_read_write(0); //dummy SPI_read_write(0); SPI_read_write(0); SPI_read_write(0); for(i = 0; i 《 8; i++) { id[i] = SPI_read_write(0xFF); } FLASH_CS = 1; } u8 EN25Q64_read_status() { u8 r; FLASH_CS = 0; SPI_read_write(EN25X_ReadStatusReg); r = SPI_read_write(EN25X_Continue_Read); FLASH_CS = 1; return r; } void EN25Q64_read(u8 *buf, u32 addr, u16 num) { u16 i = 0; FLASH_CS = 0; SPI_read_write(EN25X_ReadData); SPI_read_write((u8)(addr) 》》 16); //24bit地址 SPI_read_write((u8)(addr) 》》 8); SPI_read_write((u8)addr); for(i = 0; i 《 num; i++) { buf[i] = SPI_read_write(EN25X_Continue_Read); } FLASH_CS = 1; } void EN25Q64_write_enable() { FLASH_CS = 0; SPI_read_write(EN25X_WriteEnable); FLASH_CS = 1; } void EN25Q64_write_disable() { FLASH_CS = 0; SPI_read_write(EN25X_WriteEnable); FLASH_CS = 1; } void EN25Q64_write_status(u8 s) { FLASH_CS = 0; SPI_read_write(EN25X_WriteDisable); SPI_read_write(s); FLASH_CS = 1; } void EN25Q64_is_busy() { while((EN25Q64_read_status() & 0x01) == 0x01); //BUSY } void EN25Q64_write_page(u8 *buf, u32 addr, u16 num) //页写 { u16 i = 0; EN25Q64_write_enable(); FLASH_CS = 0; SPI_read_write(EN25X_PageProgram); //Page Program SPI_read_write(addr 》》 16); SPI_read_write(addr 》》 8); SPI_read_write(addr); for(i = 0; i 《 num; i++) { SPI_read_write(buf[i]); } FLASH_CS = 1; EN25Q64_is_busy(); } void EN25Q64_write_nocheck(u8 *buf, u32 addr, u16 num) { u8 *b = buf; u32 a = addr; u16 n = num; n = 256 - (num % 256); //写满一页 while(1) { EN25Q64_write_page(b, a, n); if(n == num) { break; } b += n; a += n; num -= n; if(num 》 256) { n = 256; } else { n = num; } } } void EN25Q64_sector_erase(u32 a) { EN25Q64_write_enable(); EN25Q64_is_busy(); FLASH_CS = 0; SPI_read_write(EN25X_SectorErase); SPI_read_write((u8)a 》》 16); SPI_read_write((u8)a 》》 8); SPI_read_write(a); FLASH_CS = 1; EN25Q64_is_busy(); } u8 EN25QXX_BUF[4096]; void EN25Q64_write(u8 *buf, u32 addr, u16 num) { u16 i; u32 pos; u16 offset; u16 n; u8 *b = buf; pos = addr / 4096; //扇区位置 offset = addr % 4096; n = 4096 - offset ; //写满扇区 if(num 《= n) { n = num; } while(1) { EN25Q64_read(EN25QXX_BUF, pos * 4096, 4096); //读出整个扇区 EN25Q64_sector_erase(pos); //擦除整个扇区 for(i = 0; i 《 n; i++) { EN25QXX_BUF[i + offset] = b[i]; } EN25Q64_write_nocheck(EN25QXX_BUF, pos * 4096, 4096); //写入整个扇区 if(n == num) { break; } pos++; num -= n; offset = 0; b += n; if(num 》 4096) { n = 4096; } else { n = num; } } } void EN25Q64_chip_erase() { EN25Q64_write_enable(); EN25Q64_is_busy(); FLASH_CS = 0; SPI_read_write(EN25X_ChipErase); FLASH_CS = 1; EN25Q64_is_busy(); } void EN25Q64_power_down() { FLASH_CS = 0; SPI_read_write(EN25X_PowerDown); FLASH_CS = 1; delay_us(3); } void EN25Q64_release_power_down() { FLASH_CS = 0; SPI_read_write(EN25X_ReleasePowerDown); FLASH_CS = 1; delay_us(3); } |
2557 浏览 1 评论
1966 浏览 1 评论
1501 浏览 2 评论
988 浏览 2 评论
3155 浏览 2 评论
1329浏览 4评论
576浏览 3评论
848浏览 3评论
806浏览 3评论
844浏览 3评论
GMT+8, 2025-7-7 23:33 , Processed in 0.957258 second(s), Total 75, Slave 59 queries .
