This ti Design details a solution for an automotive tail-light application. The design features the TPS92638-Q1 linear LED driver powered by a synchronous buck converter (LM53601-Q1) that is directly supplied from the automotive-battery voltage. This design helps pass CISPR 25 Class 5 conduct (...)
主要特色
9V to 36V Wide Vin range support 8 channel LED lighting in 2.1MHz Integrated, Low Iq Buck Converter
Synchronous Buck converter with 2.1MHz
Single Differential Filter for all the Switching Converters
Pass CISPR 25 Class 5 FM radio band without common mode choke
