我一直在尝试让 SPI 外设在 RT1020 评估板上与 Zephyr 一起运行。可悲的是,
我收到一个非常不明确的错误: undefined reference to `__device_dts_ord_83' 我的 prj.conf 看起来像这样: CONFIG_GPIO=y CONFIG_SPI=y我尝试了其他参数,例如 CONFIG_SPI_ASYNC,但这并没有改变任何东西。 我正在使用 .overlay 文件添加 SPI 设备: &lpspi1 { trinamic: trinamic@0 { compatible = "vnd,spi-device"; reg = <0>; spi-max-frequency = <100000>; label = "trinamic"; }; }; 我的代码看起来像这样: 剧透 (Highlight to read)#include #include #include #define SPI_TEST_DEV DT_COMPAT_GET_ANY_STATUS_OKAY(trinamic) #define SPI_OP SPI_OP_MODE_MASTER | SPI_MODE_CPOL | SPI_MODE_CPHA | SPI_WORD_SET(8) | SPI_LINES_SINGLE uint8_t my_buffer[4] = {1, 1, 1, 1}; struct spi_buf my_spi_buffer[1]; const struct spi_buf_set tx_buff = {my_spi_buffer, 1}; const struct spi_dt_spec spi_dev = SPI_DT_SPEC_GET(DT_NODELABEL(trinamic), SPI_OP, 0); uint8_t once = 0; void main(void) { if (once == 0) { my_spi_buffer[0].buf = my_buffer; my_spi_buffer[0].len = 4; spi_write_dt(&spi_dev, &tx_buff); once = 1; } } #include #include #include #define SPI_TEST_DEV DT_COMPAT_GET_ANY_STATUS_OKAY(trinamic) #define SPI_OP SPI_OP_MODE_MASTER | SPI_MODE_CPOL | SPI_MODE_CPHA | SPI_WORD_SET(8) | SPI_LINES_SINGLE uint8_t my_buffer[4] = {1, 1, 1, 1}; struct spi_buf my_spi_buffer[1]; const struct spi_buf_set tx_buff = {my_spi_buffer, 1}; const struct spi_dt_spec spi_dev = SPI_DT_SPEC_GET(DT_NODELABEL(trinamic), SPI_OP, 0); uint8_t once = 0; void main(void) { if (once == 0) { my_spi_buffer[0].buf = my_buffer; my_spi_buffer[0].len = 4; spi_write_dt(&spi_dev, &tx_buff); once = 1; } } 我不太明白,遗憾的是环回 spi 示例也很混乱。如果有人能帮助我,那就太好了!非常感谢。 |
1925个成员聚集在这个小组
36400 浏览 0 评论
4631 浏览 1 评论
6090 浏览 1 评论
6797 浏览 0 评论
4235 浏览 0 评论
634浏览 2评论
631浏览 2评论
633浏览 2评论
716浏览 2评论
819浏览 2评论
GMT+8, 2024-12-12 05:33 , Processed in 1.065587 second(s), Total 73, Slave 59 queries .
