【解决方法】
1)启动log查看: sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B sunxi-mmc sdc1: no vqmmc,Check if there is regulator sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B sunxi-mmc sdc1: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B sunxi-mmc sdc1: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 4 timing SD-HS(SDR25) dt B 一开始是400kHZ,后面是50MHZ 2)系统节点操作: root@TinaLinux:/sys/kernel/debug/xradio_host_dbg# ls dbg_ap dbg_logfile dbg_sta hwinfo dbg_bh dbg_pm dbg_tpa_node set_sdio_clk dbg_common dbg_***us dbg_txrx tx_burst_limit dbg_etf dbg_scan dbg_wsm set_sdio_clk默认是0表示即扫卡的频率 操作:echo 50000000 > set_sdio_clk 3)在dts或者sys_config.fex中修改: 3.1)sys_config.fex 402 [sdc1] 403 sdc1_used = 1 404 bus-width = 4 405 sdc1_clk = port:PG00<2><1><3> 406 sdc1_cmd = port:PG01<2><1><3> 407 sdc1_d0 = port:PG02<2><1><3> 408 sdc1_d1 = port:PG03<2><1><3> 409 sdc1_d2 = port:PG04<2><1><3> 410 sdc1_d3 = port:PG05<2><1><3> 411 cap-sdio-irq = 412 max-frequency = 25000000 //从150M改为25M的.wifi最大到50M. 3.2)board.dts 565 &sdc1 { 566 bus-width = <4>; 567 no-mmc; 568 no-sd; 569 cap-sd-highspeed; 570 /*sd-uhs-sdr12*/ 571 /*sd-uhs-sdr25;*/ 572 /*sd-uhs-sdr50;*/ 573 /*sd-uhs-ddr50;*/ 574 /*sd-uhs-sdr104;*/ 575 /*sunxi-power-save-mode;*/ 576 /*sunxi-dis-signal-vol-sw;*/ 577 cap-sdio-irq; 578 keep-power-in-suspend; 579 ignore-pm-notify; 580 max-frequency = <150000000>; //调整这个最大频率参数 581 ctl-spec-caps = <0x8>; 582 status = "okay"; 583 }; |
【实测】用全志A733平板搭建一个端侧Deepseek算力平台
1061 浏览 0 评论
1839 浏览 0 评论
1158 浏览 0 评论
1324 浏览 0 评论
全志T113双核异构处理器的使用基于Tina Linux5.0——RTOS系统定制开发
2056 浏览 0 评论
3097浏览 1评论
全志V851S开发版无法正常挂载TF卡,sdc0、sdc1报错
3574浏览 1评论
2264浏览 1评论
5174浏览 1评论
花费200元,我用全志H616和雪糕棒手搓了一台可UI交互的视觉循迹小车
9086浏览 1评论
GMT+8, 2025-7-1 12:49 , Processed in 0.499463 second(s), Total 42, Slave 37 queries .
